Enable Passive Mode on FTP Server
info
DeviceOn FTP default setting is active mode. However, FTP runs active mode may fail in cases where the server is behind a router or the server deplyed on Azure/AWS or other cloud's virtual machine. And that will cause DeviceOn initialize failure. To solve this issue, you should change FTP server to passive mode.
Step 1: Edit Configuration File​
Open the ftpd-typical.xml on text editor tool that located in
(Windows)
\DeviceOn Path\ftp\res\conf\
(Ubuntu)
/opt/advantech/deviceon/etc/ftpd/
Add the following XML attribute <data-connection> into <nio-listener> and give your passive ports range and external address.
<server >
<listeners>
<nio-listener>
<data-connection idle-timeout="60">
<passive ports="60001-60100" external-address="<YOUR_EXTERNAL_ADDR>" address="0.0.0.0" />
</data-connection>
</nio-listener>
</listeners>
</server>
"60001-60100" means in passive mode, ftp client uses port 60001 to 60100 to transfer data. You could change it to any available ports range. "YOUR_EXTERNAL_ADDR" means in passive mode, ftp client's destination domain name or IP address (domain name recommended). Replace this with a valid domain name or IP address that is accessible from external networks.
Step 2: Restart FTP Service​
Restart FTP service to apply setting.
  • Windows
    Stop and start the "FTP Service" via ServerControl tool (in system tray).
  • Ubuntu
    sudo systemctl restart deviceon-ftpd.service
Step 3: Add inbound security rules​
Add inbound security rules on your network security group (ex, Azure Network Security Groups and Firewall Rules), make sure blow ports are available.
  • 2121 (command port)
  • 60001-60100 (Passive port)
Step 4: Restart Main Service​
Restart DeviceOn service
  • Windows
    stop and start the "Management Service" via ServerControl tool (in system tray).
  • Ubuntu
    sudo systemctl restart deviceon-worker.service
    sudo systemctl restart deviceon-provisioning.service
