Agent Versions
Operation Systems and Recommendations​
Assigned Ports for Device Communication
Name & DescriptionOutbound Port
MQTT, MQTTs Message Client1883, 8883
Remote Desktop VNC Client5501
8022 (v-1.4.45 and Server v-4.7)
Hardware Minimum Requirements:
info
  • Intel® Celeron™ 1.10 GHz CPU and at least 2GB of RAM
  • 500 MB root partition for the system
  • Advantech HW with respective SUSI driver 3.02/4.0 support is required for the HWM (Hardware Monitoring Management) feature to be available
Advantech provides a device client that is used to communicate and exchange information between IoT (Internet of Things) devices and the DeviceOn cloud services, called DeviceOn Agent. DeviceOn Agent provides a rich set of user-friendly features that are intelligent, standardized and scalable.
  • Standardization
The communication protocol between client and cloud is based on the industry standard MQTT protocol. The IoT sensor data format is following the IPSO Alliance definition, implemented in JSON.
  • Portability
The whole framework is written in C language and follows the ANSI C Standard. C compilers are widely available for most platforms and allow easy porting to different architectures or operating systems.
  • Scalability
The DeviceOn Agent has a modular design and provides a plugin concept that allows flexible addition of new data sources or extra functionality.
DeviceOn Agent is support on different platforms running Windows 7 (or newer) or Ubuntu 16.04 x64 (or newer). Please contact us for others architectures (e.g. RISC) or operating systems (e.g. Yocto based Linux/Android).
Agent Architecture​
DeviceOn Agent includes two parts, one is the Core Framework and Plugins.
  • Core Framework is the main library used to communicate with WISE-PaaS IoTHub or standard MQTT broker and include below components
  1. Platform Profiler: describes the target platform (e.g., OS version, SN, Device name, MAC address)
  2. Configuration: describes how to connect to MQTT broker (e.g., Credential URL, IoTKey, TLS/SSL settings)
  3. Core Manager: integrates and manages the resources and keeps them alive.
  4. Core Command: responsible for handling commands that interact with internal components (e.g., rename, update, get capability, auto report start/stop)
  5. Plugin SDK: A plugin framework that makes plugin implement more easily.
  6. Keep Alive: A component to detect the connection between DeviceOn Agent and DeviceOn Server.
  7. Data Synchronization: kernel plugin that caches and restores data to ensure zero downtime.
  8. Rule Engine: kernel plugin that supports the threshold rule check and then sends event or trigger actions
  9. Plugin Loader: responsible for loading and managing plugins indicated in module_config.xml
  • The plugins include IPC monitoring (Advantech Hardware, HDD/SSD, Networks, Process…etc.), control function (Backup/Recovery, Protection, Remote Desktop, Terminal…), and sensor protocol collection.
SUSI ControlMonitoring and Control Advantech Hardware Platform
HDD MonitoringMonitoring Hard Drives (HDD, SSD) Usage, Healthy and S.M.A.R.T Information, especially for Advantech SQFlash.
Network MonitoringMonitoring Network Interface Usage, Throughput…
Process MonitoringMonitoring System Process Status, CPU, Memory Usage.
Power ManagementRemote Control Power On, Off, Reboot, Sleep, Hibernate.
Backup/RecoveryRemote Backup/Recovery System via Acronis
ProtectionRemote System Protection via Trellix
Remote DesktopRemote Desktop via VNC Viewer
Remote TerminalRemote Terminal Command
Remote ScreenshotRemote Screenshot on Current Screen
OTA (Over-the-Air)Remote Software, Firmware Update
System ProgramMonitoring System Program Information
Embedded ControlAdvanced Control (UWF, USB Lock, Keyboard Filter, …etc.) for Windows 10 Embedded, LTSC, LTSB
HDD PredictionBuild-in Hard Drives (HDD, SSD) Failure Prediction Model
ModbusModbus Device Data Gathering
Service PluginBridge Southbound Device Service
Local Provision PluginSimilar to UPnP mechanism, provides device fast onboarding on local network.
