Server Management Tools
Start Menu​
DeviceOn provides various widgets to assist server management, which can be found in Windows Start Menu.
DeviceOn Server Tools in Start Menu
Or can be found in installation path
C:\Program Files\Advantech\DeviceOn Server\Tools
Service Management​
After the DeviceOn standalone version has been installed, a "Server Control" icon should show up in the system tray.
Server Control Tray Icon
If it does not show up for some reason, please go to installation path and launch the program (ServerControl.exe) manually as shown here:
C:\Program Files\Advantech\DeviceOn Server\Tools\Server Management
Server Control Executable Location
Right-click the tray icon to open the status overview. A green light indicates the component is running normally. A red light means the corresponding service has stopped.
Service Status Overview
  • Management Service The "Management" service includes the DeviceOn backend core function and consists of two Java processes (DeviceOn and Provisioning Worker) that handle messages and process OTA traffic between the client and server.
  • Tomcat Service The DeviceOn web service uses Apache Tomcat to provide the user interface, APIs and WebSockets. For advanced configuration (SSL, connection pool, etc.), you may modify "server.xml" located in the installation folder.
    Tomcat Configuration Location
  • PostgreSQL Service The relational database (PostgreSQL) is used to store account, device, map, permission data etc. A GUI tool called "omnidb-server" providing access to the PostgreSQL database comes with the PostgreSQL installation and is located in the installation folder as shown below. The default account is "postgres" and the password is the one you defined during the installation. We recommend you do not delete/edit any schema, table or data, since DeviceOn might stop to work if data is corrupt or missing.
    OmniDB Server Location
    The defaut port of omnidb-server is 8000, and user/pwd is admin/admin.
    OmniDB Login Screen
    OmniDB Interface
  • MongoDB Service To process sensor data from client devices, DeviceOn leverages MongoDB to provide better performance and compression rates than relational databases. Click "Stop" to stop the MongoDB service.
  • RabbitMQ Service RabbitMQ is one of the most popular open-source message brokers and is used as "IoT Hub" to exchange messages between the server and client devices.
  • Grafana Service Grafana is a popular framework that allows you to query, visualize and alert on data from various data sources. DeviceOn supports a simple JSON API that as can be used as data source in Grafana, effectively making all DeviceOn data available to Grafana.
  • FTP Service To remote deploy the application to edge device via OTA, DeviceOn build-in a FTP service (Apache FTP) as a default storage. The Apache FtpServer is a 100% pure Java FTP server. It's designed to be a complete and portable FTP server engine solution based on currently available open protocols. FtpServer can be run standalone as a Windows service or Unix/Linux daemon or embedded into a Java application.
Reset to Default​
The DeviceOn server package includes a built-in restoration tool to revert your settings. You may need to use this if device configurations, data, apps, or system settings get changed without your knowledge. The tool will restore your server to its original post-installation state while retaining your current installation settings. All customizations made since installation will be overwritten.
C:\Program Files\Advantech\DeviceOn Server\Tools\Reset to Default
Reset Tool Location
Reset Confirmation Dialog
Server Advanced Configuration​
The DeviceOn Server IP Adjustment tool allows quick modifications when needed, without reinstalling the server. Some cases where you may need to update the IP:
  • The IT network configuration changed the server IP
  • The SSL certificate was updated
This tool can change the IP entered during initial installation to a new fixed IP or domain name. This allows edge devices to connect after network changes.
Additionally, the tool can:
  • Modify the root account username suffix
  • Enable automatic MongoDB data recycling to clear old data from capped collections
C:\Program Files\Advantech\DeviceOn Server\Tools\Server Configuration
Server Configuration Tool Location
Server Configuration Interface
  • Web Server: Modify your IP/DNS Address. For Linux Server:
    Change IP:
    sudo sed -i "s/CURRENT_IP/NEW_IP/g" /opt/advantech/deviceon/etc/deviceon/Server_Config.xml
    sudo systemctl restart deviceon-portal.service
    Example:
    Linux Configuration Example
    Change Port:
    • Manually modify the Tomcat port, you can find server.xml in /opt/advantech/deviceon/packages/tomcat/conf
    • Find the Port under Connector and change it to the specified value
    Linux Change Portal Port
    • Restart the service after saving the changes
  • Login Account: Modify a suffix to the Root account username
  • MongoDB: Enable data recycling mechanism.
  • WebRTC: Update STUN server for WebRTC, default adopt Google's WebRTC.
Server Diagnostic​
The DeviceOn diagnostic tool helps technical staff troubleshoot server issues in the field. It checks the health of all services and collects relevant logs. After running the tool, a log.zip file is generated. Please send this to your DeviceOn support representative to assist with debugging any problems.
C:\Program Files\Advantech\DeviceOn Server\Tools\Server Diagnostic
Diagnostic Tool Location
Diagnostic Tool Running
Server Migration​
The DeviceOn Server Migration tool, included in v4.4.2+, allows seamless transfer of your existing server installation to new hardware or cloud VMs (AWS/Azure). It migrates all device data, account information, configurations, etc.
Migration Tool Location
Migration Tool Interface
